TECH PAGE INDEX FAQ
Status
Not open for further replies.
hereismylife
Pa
Website
www.hereismylife.com
Tech Page Index Faq
IF YOU HAVE ANYTHING TO ADD PLEASE PM ME. THERE IS ALWAYS A LOT OF REPEATED QUESTIONS AND ANSWERS. HOPE THIS HELPS EVERYONE OUT....STILL UPDATING
PLEASE TRY AND SEARCH BEFORE POSTING...CLICK HERE
MAIN TY TECH PAGE HERE
BELT
Belt Deflection 101 Why does my belt Squeal
Belt Deflection 201 by Srxspec More why does my belt Squeal
Setting Belt Deflection
CARBURETOR
Carb Cleaning by MrViper700
More Carb Cleaning by Crewchief47
How to adjust the needle to run more rich? Pics.. STARTED BY comatoast
jetting....why needles are overlooked BY mrviper700
CHAINCASE
Add Grease Zerks to your Driveshaft Bearings-Video
CLUTCH
tuning chart by RIVERRUNNER
LIST OF AFTERMARKET HELIX ANGLES BY mopar1rules
Clutch Tuning Tips by Turk
TY Member Clutch Chart
Heel Clicker Tips by MrViper700
Understanding Helix's by MrViper700
What Clutch weights to use and why by MrViper700
Calculation of Top Speed
Clutch Grunt Tool #1 by rather-b-sleddin , #2 by bluemonster1 , #3 by caravanman(post #11)
DRIVE
WHAT DO 8 TOOTH DRIVERS DO?
How to removed Speedo insert in driver shaft
ELECTRICAL
REASONS NOT TO DISABLE THE T.O.R.S. SYSTEM
testing the indicator lights & problems with the lights
TORS Testing and Adjustment
Rubbed through wires by yamaha06
bog / rub through by destey
occasional stall by ottawaair
shuting down on its own..Help! by nojokef7
ENGINE
Piston Skirt Scuff Cleaning
Cylinder deglazing...........Tech section article?
How to-Cylinder Leak down test by Daman
LEAK DOWN TEST
Jetting and Reading Plugs and Piston Wash by MrViper700
Squishbands by MrViper700
Reed Stopper Notch
EXHAUST
SX Triple Muffler Bore
Power Valve Repair DIY
Power Valve Repair By MrViper
GEARS
How gearing affects clutching and RPM by MrViper700
OIL PUMP SYSTEM
OIL PUMP ADJUSTMENT
ANOTHER ADJUSTMENT THREAD
Oil Pump Setting, Alignment mark style Pumps by Daman
SKID
How many Grease zerks are on a Pro Action skid and where are they??
STARTING
Recoil Rope replacement
STEERING
Steering Column broke! Help!!
Bar Risers
SUSPENSION FRONT
RX-1 Skis on your Strut Sled by Dave_Vmax600
Yamaha Ski Info
SUSPENSION REAR
Dimensions to install SC4 Suspension
Rear Skid Fix-Long by BeTheViper
Pro-action Tuning Video provided by Ya*am*a*head
Setting up Your rear Suspension by BeTheViper
Installing a Cat skid in your Pro-Action Sled by Sno-Xr
Removing Shocks for Service
R&R Suspension
Hyfax Saving Techniques
ProAction install in older Yamaha Sleds
SC2 & SCIII Install into older Yamaha Sleds
SUSPENSION PARTS INTERCHANGE
Suspension Parts by BeTheViper
TRAILING ARM
TUNNEL
Wide running board conversion by BETHEVIPER
Status
