Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
Thread: My ditch banger project!
  1. #41
    Senior Member Improved sloTJ's Avatar
    Join Date
    Jun 2013
    Madison, WI
    Posts
    309
    Default
    Quote Originally Posted by super1c
    Well little by little its comming together. In between work and up north got some stuff done. Got the engine back together with the viper reeds and cages. Chain case back together. New clutch kit installed. Going with the turk set up for 600 twins. A 50/44 helix (micro belmont) green secondary spring at 60deg, and 8AB weights with 2.4g rivets in all holes. Really looking forward to see what this little twin does. Got the HID's installed and awesome again. I love these kits from DDM. They are really quality stuff and plug and play. I hope to get the skid done (BTV treatment) and installed tomorrow. If i do there is just enough snow on the ground for a ride around the yard. Few pic's of today
    Very nice! I know it's an old thread but I'd like to know what ddms you went with and how they're working for you. I have some 55w lows in my Mitsubishi and love them. I'd like to get a kit for my sx700 now. 35w or 55w? Hi and lows? How did you go about securing the ballast and wiring also? Thanks.
  2. #42
    Super Moderator super1c's Avatar
    Join Date
    Sep 2003
    Freeland & Otsego lake, MI
    Posts
    4,823
    Default
    I ran the 55w on this sled. As the season went on I was unable to run them anymore. The 55's were to big of a draw for the small ignition system. I think the stator only put out 175w. Not enough to keep battery, heated shield, and the rest powered. The stator would over heat and shut down. When cold it would fire right back up. I never got a chance to run the 35w to see if it would make a difference. If your sled is a single bulb sled it has the old ignition system. The 35's may work but I have not tried it yet. All my vipers with the 300w ignition have no trouble running hid's and plenty more. For as cheap as they are worth a try.
    2002 Yamaha SXViper - Daughters
    E-start, reverse, extended to 144" with cobra track. Awesome EdgeWrap in purple and pink!!
    04 Yamaha SXViper S - Extra
    E -Start, reverse, Ohlins all the way around, Extended to 144", cobra track! Cant get rid of this sled just yet!!
    2016 Yamaha SRViper LTX-SE - Wifes.
    2017 Yamaha SRViper LTX-LE - Mine
    THE VIPER PIT IS NEVER COMPLETE! Bipolar!!!
  3. #43
    Join Date
    Sep 2003
    Posts
    4,823
    Default
    There is plenty of room to mount everything under hood in light pod space. I just used zip ties so it was a easy change out if needed. And as it turned out it was needed. Simply unplug hid and put old bulb back in and good to go. I really like these and will try the 35 watt ballast this year. I also went with the high low kit. It doesn't make it brighter it just changes the direction of the bulb to throw the light out further in front of you. Also you must run a battery, no ones figured out how to run them without yet.
  4. #44
    Join Date
    Jun 2013
    Madison, WI
    Posts
    309
    Default
    hmph. I love the ddm kits that's for sure. Got a 55w in my 3000gt. Looks so much better than stock. Super nice.
    God is love.
    - 1 John 4:8
  5. #45
    VIP Member A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,333
    Default
    Quote Originally Posted by jasburrito View Post
    The new gasket i got had. 4 thin layers and 1 thick. I used 2 thin 1s.
    Could you please clarify which layers you used?
    Dannyboy
  6. #46
    Join Date
    Jan 2009
    Posts
    5,333
    Default
    Quote Originally Posted by super1c View Post
    I cannot find this set-up in sled tech.
    Dannyboy
  7. #47
    Join Date
    Sep 2003
    Posts
    4,823
    Default
    Quote Originally Posted by A couple of bucks View Post
    Not sure its in there. I got it off a search try twin clutch set up. Daman and all of them ran it back in the day for trail riding. Not sure it apply to the old logos though.
  8. #48
    Senior Member Open Mod norwegian's Avatar
    Join Date
    Nov 2004
    norway
    Posts
    2,362
    Default
    Can you give me a direct link to the hid kit used here?
    See the whole waterskipping at http://www.elgen.net/veivisr/srx-shooting2.wmv
    Stating the obvious is not neccesary!
  9. #49
    Join Date
    Sep 2003
    Posts
    4,823
    Default
    Quote Originally Posted by norwegian View Post
    I used HID from DDM tunning. I first ran a 55 watt but it was to much for stator to run ballast and keep battery charged ect. It would over heat stator and short out. The 35 watt worked fine at 4500 lumens. But if it was me for these older ignition systems the CREE LED’s are the way to go. Just as bright as a 35watt HID these days and not the draw. The HID does throw a bit more light down the trail but LED’s are close. http://www.ddmtuning.com/Products/MO...rcycle-HID-Kit
    Just an example of LED I was talking about. You can find them with fans but the heat sink is fine. Any lumen color you want.
    http://www.xenondepot.com/H4-LED-sno...h4-led-shl.htm
    Get with Rock from ROCTOYZ over on 4 stroke side and he can hook ya up also. He knows his LED’s / HID’s.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
