Summer Project Contest - The snake goes mono
Hi JD Viper, have you thought much more about using the rear upper idler drop brackets? my mono came from a 09 vector and i got the brackets too so was curious if i should use them or not. (These brackets apear to relocate the upper idler wheels 6 inches or so farther back then the rear shock mount location) i am currently waiting for viperguy template but i will also have the chasie from the vector it came from to tripple check my measurements. Also have you had any week spots in yours since you built it and what size track lug csn i get away with with my 9 tooth drivers or should i go 8 tooth for lower gearing? If anyone else has imput on my questions please chime in, going to be a great project and a blast next winter :)
