2003 viper track pitch
Ontario
I did a quick search on here, couldn't find anything. What is the track pitch on a 03 viper? Thanks. As well, biggest lug size I can run? Won't be using studs.
Yep, 2.52 x 48. Lots of info in old posts (circa 2002 -2004) but they may be deleted by now. You can run 1.25 and even 1.5 inch track if you remove the protectors or notch your track. Some even simply let it wear in.
