Hit a wall with my Electric start installation.
Can anyone help me out with a copy of a Installation Manual.
Either paper or electronic form will be appreciated.
Thanks for any help.
RON HYDRAULIC YAM
Skip ? is that you ??
I may have pictures of 643 harness position ,,, which dead end have you hit ? so I can look at home
PM me if this isn't skip and I can take pics of my TW433,, should be close
http://www.boats.net/parts/search/Yamaha/Snowmobile/1973/SL433B/ELECTRIC STARTER UNIT/parts.html
try here
Ron
try here
Ron
RON HYDRAULIC YAM
Have not forgot you , just busy
Ron
			Ron
no problem. I worked at it a little more.
Got red battery cable going to solenoid, where does the cable go from the starter motor?
I have 1 thin red wire and 1 thin black wire coming off the solenoid that I have no idea where these go. Both have eyelets.
I have a white wire with a bullet connector coming out of the wiring harness located behind the oil tank. Not sure where that one goes either.
Other then that I connected all other connections where I THINK they go.
