fox shocks on a 03 viper
Ontario
Is it possible to put fox shocks on the front of a 03 yamaha viper? If so how much roughly? And would I need any sort or modifications to the shocks of front end?
It's possible but you will need special mounting brackets. Carver performance used to make them. Not sure if they still do.
I bought srx shock brackets and then i made custom part from steel to change shock mounting. Steel part is welded to shock bracket. Shock mounting is horizontal 40mm and vertical 20mm from stock. I'm sorry for bad english.
Hope these pics help to understand.
