Corey9965
My last SRX had the Bender Transfer rods on it so adjustment was pretty simple. How should I set up the stock pro-action transfer rods for grass drags/ radar runs. I'm looking to just keep the skis off the ground a few inches. None of that skis to the sky crap. Lol. Thanx.
You can try different shims with the plastic spacer in place. I took mine and cut the bottom one in half to get more transfer but not to the sky.. You should strap the suspension down also if you want to grass drag. less air under the front end. You can also adjust your limiter straps to stop the transfer rate. You will have a lot of trial and error before you get it perfect for you.
Corey9965
Ya I have an idea of what I want to do with the suspension. I was just curious on where to place the shims or washers on the t- rods. Like if I need more washer on top or bottom. There is a big spacer on the bottom now and a skinny shim on top. Thanx for the help.
