putting the head back on a viper?
jdub-viper 700
upstate new york
need quick help please...do you need to use a gasket maker when putting the stock head back on? and can some one give me the torque specs for the head bolts?
thanks, john
No gasket maker. Use the gasket. If it's new you can just install it but new or used I like to use a very thin coat of copper spray on both sides. Don't get carried away with it
Do the longer bolts all go in the middle cyl? Or across the middle from left to right?
Sent from my E6560C using Tapatalk
the center bolts are recessed roughly 3/8 into the cylinder so that alignment dowel pins can be inserted. Two dowels align the head on the far left and far right head bolts.
