adktom
I have read a lot on here that the best mod you can do to your viper is clutching. It seems very confusing to me. Is there a kit or setup that you can buy that will improve the performance relatively easily? I do mostly trail riding and would like a little more performance from my sled. thanks for any input.
http://www.totallyamaha.com/snowmobiles/aaTECH/tuning page.htm
i used an rx1 helix its 51-43 and a hauck primary spring black I believe and green secondary at 60-70 wrap. I was happy for awhile now triple piped and ported with heel clickers.
BornYamaha
The easiest is to go with the dn20 srx weights, most likely loaded with the 4.5 gram rivots in both holes with the rx1 secondary helix and the green secondary spring setup listed in many threads on here. If you want to try cheap first try the same thing with stock weights. If you want one of the best more expensive setups search out Mr vipers heal clicker setup. You will need to fine tune any of these setups to your sled to get the best results. Many on this site would be happy to help you through getting it dialed in.
Sent from my SM-G900V using Tapatalk
