Klotz Oil..
Not sure its the same but I have been using Outboard Two Stroke oil for 15 years in my non power valve sleds, chainsaws, weed eaters, leaf blowers, two cycle generator pretty much anything that uses two stroke oil I have and still use outboard two cycle oil. The sleds show no abnormal wear and are clean when I have had them apart for normal maintenance.
A buddy learned this the hard way a few years ago. Klotz oil that we used to run in our stand-ups...the lesson is...Do not use ANY oil that has castor in it. It gets gummy in cold weather...squeekaaroosskkiii. I'm sure jet ski oils that have no castor would be fine
I was just looking at the ingredients,I dont see any castor oil....Thank You for the info...I got a sweet deal on a case..
We have sold and raced with Klotz for years, the Skicraft doesn't have to low temp flow additive and will damage the engine, stick to the technoplate for snowmobiles.
