Srv560
Installed some led light on my Srv. I put one on my air box and also along the gas line tube because it's hard to read in the dark. Also put some in my vents. Use a total of 5 strips and ran it off my portable fish finder battery with a resister. Left them on for 3 days straight and still had power. There bright but a rode test with cold weather will tell.
z
Sent from my iPhone
Sent from my iPhone
tippmannator
Looks sharp!!!!
Sent from my SCH-R530U using Tapatalk
Srv560
Thanks. Thinking about putting some under the running boards but the sled doesn't sit high enough.
Sent from my iPhone
Sent from my iPhone
Whereswade
Could you put them in the tunnel, or is that just askin for trouble?
Srv560
I think you would run into problems if you mean on top of the tunnel or the sides. The top the snow and if you run ice diggers and bottom out there goes all your work
Sent from my iPhone
Sent from my iPhone
