Cooper0809
Just wondering if there's a thread in the tech section about how to do a rebuild. I looked but I couldn't find anything...might not have been in the right area. I think if there isn't a how to, somebody should do one with pics!
Srx007
Which engine are you going to be rebuilding? You will definetly need a small hone, which can be found at a partsource, maslack, canadain tire, etc one particularily that you can place in the chuck of any drill, usually 40$. You will also need a lubricant for it, I have used a lubricant as light as WD-40, others may say not to but it works just fine, used that on my first 3 rebuilds (cast-iron AND nikasil bores) yes a nikasil bore should be honed so rings can seat properly. Either a top end gasket set or a full engine gasket set would be required. If sled is yamaha get it from dealer instead of Royal Dist. some gasket material will be able to be re-useable which I would rather pay the small extra...just a start...Why a rebuild....
super1c
Super Moderator
Blue monster did a engine build thread. Was pretty detailed if I remember right.
super1c
Super Moderator
Cooper0809
Thanks guys! I'm going to be rebuilding my spare 540 motor..I'm assuming the same principals apply.
Cooper0809
drew24
A steering wheel/harmonic balancer puller works if you are talking about the flywheel.
staggs65
Best thing for a rebuild is the yamaha service manual
Cooper0809
Perfect! The old man has one...
Cooper0809
I guess I'll see if I can find one on eBay.
Cooper0809
1990 xlv 540
Cooper0809
I guess it's probably time a become a member anyways...lol
staggs65
Have it. Sign up and pm me
Cooper0809
Can I just use credit card through paypal? I don't have a paypal acct tho...
staggs65
When you click on the buy now there's an option that says don't have a PayPal account pay with debit/credit card
