srx problem need help !!!!
gregory110
Canada
I have a 98 srx 700 and I losted all my gauges (fuel.revs.speed.) but every mile I put on shows so I know the key is good on my cable ..and my light started to blink on the hi side and my hand warms give out but my thumb one is still working....has anyone heard or seen this before thanks
Sounds like a rub through on main harness under engine. Pull main harness from under engine and give it a good look over, common problem. Easy to do just disconnect from hood harness, tie a string around that end so when done its easy to pull back through. Then undo clips at bottom of belly pan that run under exhaust and pull harness out from end up by air box. Best to pull air box so you can get a good look and reach on it. In fact not sure you could even do it without air box out.
Yes I had a rub through where a clip had come off and the cable was rubbing on my pipes. Killed all my gauges
Sent from my E6560C using Tapatalk
