secondary sheave center distance offset
TrueBlue
VIP Lifetime Member
I have a 2000 SXr 700 & I need to know what the sheave center distance would be from center of primary to center of secondary. Also need to know what the sheave offset would be.
Thank's in advance Rich
Once the offset is adjusted & the secondary is bolted back on, how much free play should there be on the secondary. (Move meant of secondary back & forth on the shaft.)
Again thank's in advance. Rich
I rode a whole weekend once without the secondary bolt. I noticed it once we were out about 100 miles. I found the bolt on my bench at home. My point is, as long as you have at least 1/8 - 1/4 freeplay you should be good. I wouldn't recommend running without the bolt.
