boats4every1
I just bought my first sled. It is a 1998 srx 600. I have a few question about it. like RPMs at certain speeds, and rpms before moving. THe sled reuns about 6000 rpm at 50 mph. It seems high rpms to me compaired to my cousins 94 vmax 600. ait seems to not move until around 4000 -4200 rpm. I just wanted to know if this is normal. before I bough the sled the guy that owned it had the power valves rebuilt, carbs cleaned, new reeds, clutch rebuilt with weights and springs. Any adivce about this sled and recommendations on tunig would be greatly appreciated.
kawirider00
thats fine its just the engagement rpm alot of peoples is like 4800ish
98srx6
boats, your engagement is perfect, did you happen to notice your rpm's at full throttle?
boats4every1
My rpms at wot are around 9500 +- 100. thisis what the needle seemed to point. bouncing around alittle at that speed.
srxxx86
- Dec 31, 2004
thats way to fricken high i think, srx700 top rpm should be 8300-8500.
yamyrider
WOW...you are losing power reving that high...You really need to fix that.
Check you clutches.
Check you clutches.
yamaholic22
yea you need to get those rpms about 1,000 rpms lower
boats4every1
Sorry guys you are right. It is running 8500 +- 100 rpm. The 9500 was a typo. I do have another question. behind the left cyl. there is a nob that is marked on/ off. The nob is on what I think is a cooling rail. What does this nob do and should it be run in hte on or off position. Does air temp make difference in running it on or off?
yamaholic22
that knob is for the liquid heated carbs, it should be on when you are anywhere below 25*F, and off anywhere above that. You will find it very hard or even impossible to move once the engine is warmed up, so make sure that if you want to move it, you do it before you run the sled.
boats4every1
thanks yamaholic22. I thought that it had something to do with the carbs but I wasn't sure exactly what it did.
I never use those carb heaters. I used to use them, but my sled would like to foul plugs when I had them on. Keep them off all the time and don't run into any problems. Just my .02.
