joe, i might be wrong. i do believe their different. the hoods on a sxr and a srx are not even close for example. now with that said, you posted a 97 sx which might work . not really a answer. 3:16x (yammie tony)
not the same, sx is narrower in the front section and your pipes will not fit then, the srx is wider in front of the shocks to front bumper for the triple pipes.
The pans fit, but the hood from either sled will not work. You will need an aftermarket hood to clear the SRX pipes. I am running a fiberglass hood that has the bottom edge built up about an inch. I am also running a Hauck silencer IDK if others will fit with the SX pans.......SRXtreme
