Vmax 4 big bore help
95vmax4880
Mn
Ok I need help I have a vmax 4 880 and cant get pistons through wiseco unless you order 12 & at $200 a piece. Hauck don't have any. Only other option is a kawasaki 440 intruder piston hauck said. But have to modify it to work. Does anyone know any info to make the bore bigger like to 1000cc. Any help appreciated
I would say the 700 crank un modified woul give up the ghost long before 1000ccs could be obtained.
Elaborate as that makes no sense.
opsled
PS, 95-880
Some have done 1000cc 4's but it ain't cheap or easy. Some will say it isn't even worth the effort as crankcase volume won't support the CC increase. Vmax4.com has some info on it if you search there but not much.
