Throttle Junkie you help alot of people with good answers. The more you help people, the more I remember and thats good. Thx
I may have taken the quote the wrong way from both of you. Sorry about that. It looked like when I posted what I do out of the norm, then the next post starts with quote "DO NOT adjust"??
Both of you and everyone working on old sleds with old clutching are going to run out of tuning parts for the primary. You only have so many weights, springs and rollers you can run / test. After that your forging your own weights or tuning with your driven (or both). Now your playing with your old driven. How may aftermarket helixs and springs did they make? They didn't have many when the Exciter was new even less now. So you now you look for stuff that may not have been made for it, but you can get it to work (cut down / re-drill holes..whatever it takes)
So how do you know what your even looking for? Lets use your sled as a example. I test belts first, soft, hard and top cog. Mine was always top cog soft. Your sled likes 50*, unless it's deep snow then 60*. Now you need a real number for each in lbs. From that you will have your area in lbs to work in. Now swap springs and retest pull in lbs or redrill holes move old spring. Take notes and go out and retest. You can use a bath scale, 2 wood blocks with a hole as a holding jig and jack to check your spring rates if you have to. Use SAME start point and end point of spring collapse, take notes on LBS of each spring. So at 3" gap scale shows 80lbs, at 2" gap 120lbs... so on. Test each spring.
Now you have GOOD notes on spring twist in LBS (back shift / up shift), and spring rate side pressure (belt slip). You know what spring you have and what it SHOULD do.
Then I make a grid on paper and go out and test:
Settings / Hole shot / mid / topend
Black spring 16lbs twist / good / ok / poor
