Thermostat issue 2001 srx
vintage srx
harrow ontario
Tore my brothers motor down and found the thermostat in this condition has anyone seen this before ? I was inspecting the motor because two power valves had broke no damage to engine .
Second time this has happened on this sled my 02 hasnt happened yet with 20000kms .Just wondering if its a faulty therm or something else .
So perhaps i should leave it in? The 2001 sled i just took apart had a perfect t-stat. I have not checked my 2001 with 8000 miles but i will. Never heard of one going bad.
It's been debated before. Without a t-stat you will need to put a plug (with a small hole drilled into it) in the small hose leading from the t-stat housing to the coolant bottle. This allows/forces the coolant to constantly circulate through the ENTIRE cooling system all the time as apposed to circulating through the motor until the t-stat opens which then pushes a large volume of COLD COOLANT to enter the engine just when your about to hit the throttle. I use this setup in both my SRX's with no concerns and no issues, warm up and go. More consistent temps verified with temp gauges. Your choice!
