Help leaking oil issues already cleaned PV
striker7284bass
rochester, ny
I have an Oil leak that I can't figure out where it's coming from. I've already cleaned the power valves and it looks like the cylinder farthest from the clutch has leak under the exhaust. I attached pictures for reference. Where could the oil leak be coming from.
Having a difficult time seeing exactly, but spray some grease removing solution everywhere where you see oil and clean it up better. Start it up and then check again. Maybe you might have a bad seal between either the crank casings, or between the top crank case and cylinder. If there is no oil coming out from any of those areas, maybe you just might have a bad gaskets that your valves bolt onto your cylinders.
