cheroy
hello
what is the tallest lug and stud combo I can run without modification to the track or tunnel
current running a studded 1" hacksaw. 121X15
not sure what the stud height is cause they are kinda worn but I am certain its the appropriate height for the 1" lug.
tunnel protectors are installed and the drivers are factory default.
any advice would be fantastic
thanks
thanks
Agpetro
If you don't want to mod you're track then stick with a 1in track. Under my dad's 02 vmax and my 03 viper we are both running 1.25in ripsaws with 1.325 woody gold digger studs. Running a 1.25in track you will need to trim it around .25in between the track windows to make it clear the tunnel and front heat exchanger. It's not really hard to trim a track at all though. Takes around 20-30mins to do the whole track if you were wanting to go with a better lug.
1" with no mods. 1.25" with trimming the track. Studs work with 1". I had about 1/4" clearance from the stud tips to the front cooler. I used 1.375" studs on the 1" hacksaw (I think, I cant remember). I have had both and didnt notice much difference between the ripsaw and hacksaw. Big upgrade from stock though...
http://www.totallyamaha.net/forums/threads/73656-1-25-ripsaw-under-a-viper?
A couple of bucks
Stud your Hacksaw and call it good.
