chadzeilenga
Picked this skid up. Believe it to be a Phazer. What year? What issues do I need to look for on it?
Planning to replace bearings, paint and slide under my SS440.
looks like a 90 skid. first or second year 121 if the rails measure around 46" following the bend. should have an upper cross bar with idlers with it to support the track if my guess is correct. obviously the rear shock is leaking and the front appears to may be starting to ooze.
good match in my opinion for your ss project once you figure out the needed extension for the extra track length. 83 ss was still the 116?
chadzeilenga
How do I correctly measure the rails?
Also, where can I get replacement shocks?
Throttle Junkie35
Check the lower rear arm pivot shaft. The part that bolts to the rails. Check all the shafts while your at it. I bet at least one will be seized. Pretty typical. You can get shocks at your dealer, ebay, swap meet etc, or place a wanted ad in the TY classifieds.
