Ovation Carb
SpartaSXr
Western Michigan
Found a 1989 Ovation but the carb is gone. Anyone have one for sale ? Or is there a way to convert it to a single flat slide carb ? I looked it up on here but the link will not work.
well you need the intake from any 340-410 enticer 78 and up. carb with cables from 85/86 up so it has the tors switch on it with all the cables if you can. might be other years for the carb. I do have a spare carb from a 78/79 et340 with the choke cable but shipping would not be pretty.
Thanks ! I have looked into an Enticer manifold and carb, not sure if I will need the cables and airbox as well. I need to long track it so I will be looking into driver shaft swap to get a 121" with extro drivers under it. Want a fun X 2 sled for the big Lake Effect days I dream of :letitsnow
