ThePunisher
- Jan 25, 2005
How do you change the drive belt on a 97 vmax 600 sx?
Help!
Help!
place your palm on the helix of the secondary clutch (the part that sticks out further than the rest) and push in with a twisting motion clockwise. this will split the sheaves allowing you to pull the belt off the secoudary and then off the primary.
ThePunisher
- Jan 25, 2005
Thanks Roach!
grapeape
setting the parking brake helps too, just remember to flip it back off when done. Also, take a 12mm wrench and use it to turn the secondary, makes it easy on the hands, but it does not seem to wok on my roller set-up.
