JERSEYJOE
I am going to glass bead my clutches to clean them should I not also glass bead the sheaves where the belt contacts? The surfaces are extremely smooth and I do not want to damage them with the glass bead process. Can I do this?
I've never used that method to rough up the sheave surfaces but I can't see why it wouldn't work.If your unsure just take a scothbrite pad and some brake cleaner and scrub radially on the sheaves,from the centre out,rather than around them.
JERSEYJOE
So am I correct in assuming that the CVT system works best when the sheaves are NOT really smooth and shiny?
Well that's what I've gathered from years of reading posts on this forum. I believe it's the same concept as deglazing a cylinder,a rougher surface will be better for the belt to grip.
Sent from my XT1058 using Tapatalk
Youllbe2nd
I do it all the time works great. Protect the shafts with something
Sent from my E6560C using Tapatalk
shaggyzr2
I've used baking soda in my blaster for cleaning clutches, makes them look brand new and doesn't rough up the surface too much.
What kind of pressure do you use with baking soda? I've got a spot blaster that I'd like to try this with.
shaggyzr2
I don't remember what I used for pressure but I did use my little spot blaster. I've tried other things like sand and glass and it just seems to rough up the surface too much. Make sure you wear a respirator when using soda!
shaggyzr2
Blasting with sugar works good too! lol I had a bunch of old sugar laying around, instead of throwing it out I found a use for it! lol
Hmm I'll have to raid the cupboards when I get home from work and see what's in stock.
JERSEYJOE
The glass I use is extremely fine. I do a lot of intake manifolds, piston skirts and valves. for my JEEP projects. How about i'll try it and post up after?
03viperguy
interesting, ever get around to doing it? curious how it turned out
JERSEYJOE
Yes I glass beaded my SRX clutch and my Apex clutch.. after that I used scotch brite the sheaves. awesome finish
