Srx trouble code...1 longer flash then 3 quick flashes
j2hizzo
southern maine
Is this code a coolant temp code? If so then how do I fix? I just did top end so coolant was drained. I got nose up with cap off getting air out
I would always forget to plug that one back in when doing top end work. Little bit of panic the first time but after doing it a couple times I even remember it the first time once in a while.
likely forgot to plug it back in, its on the bottom of the water rail so its easy to overlook, not up in the head like a viper.
