Hi, new here, been reading discussions and I know there's a lot of knowledge here. Anyway just picked up a 91 SRV the top of both rear shocks rub on the track, not sure why, I've removed the rear skid cause I'm going to replace the track any thing to look for when I put it back together, or should I replace it with an xtra 10 or any other suggestions?. Thanks a lot
Throttle Junkie35
I think you may have some weird stuff going on. The top of the rear shock may contact the track from time to time due to the track bouncing and flexing. The front shock has absolutely no way it can hit the track as its between the linkage. Can you post a pic of your skid??
Ok I'll snap some tonight, Thanks.
I'll get some better ones once I'm home, im wondering if it was assembled wrong cause the front shock really sticks up high
Srv560
Make sure everything is greased and also I think there three or four suspension rods that come out they should be greased every year. A lot of times there are grease fittings on there . I have a 90 and I had to weld mine on. Good luck
Sent from my iPhone
Sent from my iPhone
Pretty sure I've got a broken bracket, anyway you could shoot me a pic of what yours looks like thanks again
Throttle Junkie35
Yep, thats really broken. Here's the parts break down for it. #36 Part number 8U7-47418-00-00. Maybe this will help http://www.portyamaha.com/fiche_sec...Snowmobiles&make=Yamaha&year=1991&fveh=176113
Srv560
Your on this site too, couldn't find the part. I just have parts for the newer skid .
Sent from my iPhone
Sent from my iPhone
Srv560
I have that broken bracket. If you don't Full throttle junkie.
Sent from my iPhone
Sent from my iPhone
Srv560
Carb boot oem vs aftermarket
OEM
aftermarket
Sent from my iPhone
Sent from my iPhone
Throttle Junkie35
I would send that carb boot back and find an oem or genuine Mikuni flange. That boot wont seal correctly because there isnt metal in the flange like the original. It will cup when you torque it down. I've tried the cheap boots in the past with poor results. Also, I can guaranty that flange will dry rot and crack within a year.
Srv560
Could, I just grab a bunch. 20 all types $10 bucks can't go wrong
Sent from my iPhone
Sent from my iPhone
A couple of bucks
That's a FACT!!!!!! They'll crack over the summer and and you'll burn her down the first ride of the next season.Also, I can guaranty that flange will dry rot and crack within a year.
Srv560
Yes it will. At would a company sell that product noing that hole is off? Like I said I just grab a bunch of them they where cheap and there about 11 oem with different sizes. But I would of never to look for that . Thanks Shawn .
Sent from my iPhone
Sent from my iPhone
A couple of bucks
Tell me where they were made and I'll tell you an answer.At would a company sell that product noing that hole is off?
Srv560
5 of the #38 boot flange bags say spi and RSI. The ones # 20 are for 40 or 44
and some odd ones are in bags sealed with no lettering.
Sent from my iPhone
Sent from my iPhone
A couple of bucks
Quality is not much of an importance in Taiwan. I'm not saying everything s¥cks because it doesn't. It's a cr@p shoot. Sometimes ya win, sometimes ya don't.
Hey, thanks for the help guys, I found the suspension bracket, we'll be nice to get this thing back together, still haven't found the airbox side carb boot, maybe eBay? Has anyone ever used one that worked off different machine? The pics and one your referring to is on the intake side.
