SXVIPERGUY21
		super1c
Super Moderator
Assuming there are no other problems that should fix ya right up.
			SXVIPERGUY21
Ok thanks superc1! Also is there a recommended place to buy the gaskets and how hard is the job??
			there is a drain there too. if you look when you have it apart, you will see the small hole there to drain the oil. probably just clean the valves, housing and the cable too. that should fix it...
Edit: after looking at the picture closer, i think the drain is the next gasket closer to the motor. Regardless, clean them up and ti shoudl be better.
You might also need new o-rings with that.
			shaggyzr2
I've got a gasket and o ring kit if you need one, $35 shipped.
			Envy3699
Where did u buy if from? Could u send me a link?
