Silver Bullet
I have a 98 vmax 600 sx with a hole in the front heat exchanger from a stud last year - This summer I bypassed the heat exchanger and added a heater core in front of one of the air scoops on the right side. I took a few short rides this year but overheated only to find out the cooling system was not full and probably air locked. I was able to bleed off most of air and now I've run about 20 miles with no problems but I am concerned that I may overheat on a longer run. I am going to add a temp guage but I was wondering I would like to add a rear heat exchanger I've seen some used rear heat exchanger from parted out sleds. What tunnel designs are comparable to my 98 SX. This would help in my quest for a rear heat exchanger.
Silver Bullet
Silver Bullet
