I have the template but I cut the part off where it shows the stud patterns for various stud options...96,120,144 etc. Does anyone here have a pic of that chart ?? I have 144 studs now and want to remove to get 96 total. I need to know which studs to remove....
thanks in advance
thanks in advance
bluewho
Just remove the ones closest to the centre of the track and leave the ones that are close to the rails. The stud pattern plate is for dummys that cant do math and like there pics all in a straight line were they are the least effective.lolk
need to know where the studs are in the track. Center outside? If in the center you can do as Bluewho said. If on the outside take those out.
Woody's template says 96-use all 1&3. 120 -use 1,2&3. 144-use 1,2,3&4
ok thanks guys,I'll have a look at the track again to see if it is worth the effort to remove the studs.I would have to remove many double platse and go back to single plates then
