SXVIPERGUY21
Cleaned the power valves, changed all the gaskets and seals. Everything went very smoothly and wasn't that hard of a job (even being fairly new to sleds). My question is how tight should the cables be in the servo motor once the pulley has rotated? ( the pulley turns when the throttle is pressed). I took a video but could not get it to attach.
snoprokidf6
SXVIPERGUY21
That's perfect thank you!!
