JERSEYJOE
Does anyone know the exact nature of the coating that Yamaha uses on the cylinder heads? I do not think that powder coating will tolerate over 600 degrees and I assume that the head external gets that hot????
The folks at JET HOT tell me that their ceramic coating might hold in heat. Is this potentially a good thing or bad?
Bottom line: what type of coating will work best on the heads?
shaggyzr2
I wouldn't use any coating that will hold in heat, I'd just use Hi temp engine paint.
