How to check kill switch?
CaptBillvmax700
Indiana
Just replaced my stator and have no spark, all my cords are plugged back together, jut wondering how to check my kill switch to see if it is functioning correctly
In you handle bar pad there sould be a triangular plug coming from the throttle unplug it and get a tester switch it to continuity stick the post from the tester in the black wire and the other in the black-white wire and push switch down if you get a beep it works then pull up and the beeping sould stop.
