92 Venture GT Oil Pump gear removal
Brinkkl2000
West Michigan
Hi guys, I am doing a full rebuild on my Venture and want to replace the main seal on the pto side. There is a gear that drives the oil pump on there. How does that come off?
Thanks Throttle Junkie, almost as soon as I posted this I remembered I had bought a bearing splitter last year and figured I would try it. A little persuasion and it popped right off, thanks! Threw the crank in the freezer overnight, heated up the gear a bit and it went on pretty easy!
