kaymcc
Now I'm trying to figure out why my kill switch isn't working. I unplugged the two wire connector that's under the handlebar pad and shorted the pins with a screwdriver and the engine didn't die like I thought it would. The harness disappears under the engine somewhere. Where is the other ends of those two wires? I noticed that the TORS switch has been disabled over the years by somebody. Is it related to the kill switch? I plugged the TORS in and the engine wouldn't rev up and the kill switch still didn't work. Would I have a bad TORS switch and kill switch? How do you change out the kill switch without damaging handlebar warmer?
drew24
The kill switch is the 3 wire connector. I believe it is the black wire and the black with white stripe that connect when the switch is off
