Track rubbing shock/8 tooth
Youllbe2nd
Canada
Anyone have shock clearance issues when switching to 8 tooth driver? Looks like my track is rubbing on the front track shock and a bit on the rear shock adjustment nut. Is my skid whipped? There's a mod where I can put a bearing on either side of the shock eye so the track runs on the bearing instead of the shock...is this clearance issue common?
Sent from my E6560C using Tapatalk
