Is anyone here still repairing power valves. YA*AM*A*HEAD's thread appears to be a dead end. Thanks.
A couple of bucks
A couple of bucks
I thought the roll pin idea was
staggs65
Mrviper700
Youllbe2nd
The roll pin works or using the link above the guy used a 3/16 tube. However I can't see these two things working if the end is already pulled through... Mrviper700 is the guy who repairs them proper.
Sent from my E6560C using Tapatalk
I have been trying to contact him. Do you have any contact info you can share? Thanks
super1c
Super Moderator
The tube idea will work fine if pulled through. The only way it wont work is if you have totally wrecked entire end. I havent (knock on wood) but if i do have any pull throughs ill just do the above repair. I read also a SS rivet body works well also and i would use some green locktite to secure repair. Just let dry at room temp overnight then GTG!!
Interesting - I'll look into this.
That link is dead. Does anyone do the repair? Or have a link to a DIY?
Thanks!
Thanks!
