xrrider
I recently acquired a 95 vmax 600 for free. I am in the process of trying to get this sled running. I absolutely can't get spark out of it. Replaced stator, coil, cleaned up flywheel, checked all connections and wires, tested kill switch, ignition switch, pulsor coil, all test out good. Only thing left is the cdi, do these usually go bad, is there a way to test? I've searched countless threads
trying everything, just can't get any spark at all. Advice needed. Thank you.
