Youllbe2nd
What are these wheels? They measure 5 5/16, they have a 6204 bearing molded in. I can't find any 5 inch wheels with 6204. I thought only they rear viper wheels where the molded bearing ones?
Sent from my E6560C using Tapatalk
Youllbe2nd
Anyone know of a 5 inch wheel with a replaceable 6204 bearing?
super1c
Super Moderator
Have no idea?
A couple of bucks
As long as you have adjustment on the rear track tensioners, I see no reason why you couldn't use them.
Youllbe2nd
These are the ones I pulled from my skid. The bearing is molded in. I dissected one to find out what bearings I need and its a 6204. There are aluminum spacers with the blocks machined specific to this bearing. I'm looking to replace these with a new wheel with replaceable bearings. Any sleds out there run a 5 inch or 5.350 or something with the 6204 bearing? Everything I've found is 6205 or 6004. PAIN IN MY ***
drew24
Not sure what the aluminum blocks are you have but the 6204 and the 6004 are both 20mm id. Wouldn't the wheels with 6004 work?
Youllbe2nd
I suppose i could. I might have to put a washer on the spacer to compensate because the 6004 is 12mm wide. The 6204 is 14mm. I'll rig something up. The wheel spacers are machined aluminum. I'm assuming they are after market. Not letting me post pics right now for some reason. Thanks!
