VMAX MM diagnosis code flash
epulk
Ontario
Hi guys what would be the potential cause for this code to appear? just had my sled out today and it threw this code at high RPM/speed (100 kph)
Sled is a 96 VMAX 600 Mountain MAX
long, long, short, short, short = discontinuity on the solenoid valve actuated power lead (to ECU)
Could be going out or you could have a bad connection...
Maybe someone else has a had this problem and can give you a better answer..
