Polishfreak
Hey guys.... I'm much more of a polish & paint kinda guy buy am looking for the best known clutch set ups for 03 Viper & 02 SRX to start dabbling into the performance side....  So many opinions out there, but if any of You that know what makes these old girls come alive thru correct clutching please drop me a line !!!!
Pics of the sleds coming soon...
Cheers Lads, thanks for any replies
							http://www.totallyamaha.net/forums/threads/99903-01srx700-Hot-Trail-setup?highlight=srx+clutching
http://www.totallyamaha.com/ select snowmobile then engine then almost to the bottom is jetting specs on clutch tuning page
http://www.totallyamaha.net/forums/...-01-700-I-know-I-know?highlight=srx+clutching
lot more on here
lot more on here
Polishfreak
Thanks a lot for the reply & direction.... I dug up a set up from Turk that's highly recommended and simple..... 53/43 multi angle helix, Yamaha green secondary, 4.5g weights in the tips.... 3900 engagement, 8500 top end rev and pulls all thru the powerband.... Sounds like a winner, thanks again
			That's a good route should keep you hapiy for awhile. If you ever decide it's time for more you really won't be out much if you change direction and go with heelclickers or something along that line.
			dakotaruston13
Went from my 2004 stock viper last year to light performance modded viper this year i would recommend you to my set up 100% mines night and day different from last year you better have a good hold on the bars when u hit the throttle now.
This year I did:
- 136 Hartman rail extension and skid relocate w/ 1.5" lug paddle track
- Boyesen Rage Cages
- Anti Rachet Drivers
- WEISCO Forged Piston Kit
- MBRP Trial Can
- most importantly Heel Clicker Clutch Kit!
My clutch kit has a red primary spring, yellow secondary, and the heel clicker clutch allows for hundreds of different options, the bottom end was crazy with too much track spin when first installed now dialled in will little bottom end track spin and just pure of the line hole shot power and still rev out to about 120mph
This sled went from your average viper to a rocket from start to finish, better ride, better off trial and on trial, blows many new sleds out of the water, still good on fuel, and all and all just amazingly fun to ride! would recommend to anybody! Just my 2 cents worth
Sent from my iPad using Tapatalk
			This year I did:
- MBRP Trial Can
Polishfreak
Hey there !
Thanx alot for the detailed reply, sounds like a great set up on Your sled. I haven't been on here for awhile due to the brutal winter we're having but I've planned a trip up North in a few weeks and getting the sled dialed in... I've changed my clutching to Turk's popular set up, but went with a Dalton Racing multi- Angle Helix instead of a Yamaha Helix.... Huge improvement vs stock for sure. Do You have any idea if the Boyesen Rage Cage offers increased performance over their power reeds ? I currently have power reeds in the sled....
I had my skid out recently any noticed the prev owner had the limiter straps pretty much as loose as possible.... IS there a reccommended setting for good transfer & performance on the straps ? Thanks for any input !
Cheers
Cheers
http://www.totallyamaha.com/snowmobiles/aaTECH/TechIndex/SUSPENSION.html
http://www.totallyamaha.net/forums/threads/34503-setting-up-your-suspension
reeds in a stock engine stock work best you wont see much gain with any aftermarket. plenty of info if you do a search.
