Can I Upgrade My Avenger 3?
FrankieJames7
Alaska
well i got my racepak Avenger III in the mail and found out it is the standard racepak. I want to be running 3 EGT's(which i already have), coolant temp, warning light, engine rpm and drive shaft rpm.
there is nothing above the "Analog Sensor" which i'm guessing means it can't tell the coolant temp. it does not have the warning light harness but if i just replace the power harness to a warning light model one will a warning light still work or would i need to upgrade the entire avenger?
if you have an analog sensor, warning light, and a downloadable racepak avenger III i am willing to trade mine with some extra cash for an upgraded one.
