80 SRX carb tune question
sledtillsed
Edmonton
Hey guys. I just picked up an 80 SRX. Don't have any experience with these but think the previous owner made some changes. This one has no oil injection or tank. It does have butterfly carbs. Were they used on the 80 ?
I noticed an adjustment screw with a. White knob on each carb below the intake throat. Assume this is a high speed adjustment ?? Please confirm and where should this be set ? The pointer tab on both now are straight down. Also does turning in lean it out and backing out to richen it up ? I am taking it out this weekend but want it set up properly
Any help is appreciated
Cheers
those are not stk carbs for the 80 srx. 80 srx had butterfly carbs, the white knob were used in 76 though 79 on the yamaha round slide carbs, and yes it dose rich,in or lean your fuel mixture. i believe safe setting was knob strait down. 3:16x (yammie tony)
