Help, it won't start
norwegian
Well-known member
norway
97 Vt 500. Had it at the dealer to clean the carbs. Started at first pull. Ran good on chocke, once I took it off it ran poorer and poorer
and now it won't start even with full chocke. I tried pouring a little gas through the plugholes, and it ran while the gas in there lasted. What's wrong?
Plugged pilot jets?
I would have to say that that is where you should look first.pilots should be plugged.It is not getting a steady flow of fuel.Whose sled is this by the way? You home for xmas I gather.
Must have sat for a while with no fuel. Might want to replace it. My buddy had a skidoo that sat empty for a long time and the line in the tank was so brittle it broke apart and ended up with a tiny piece that got stuck in the needle and seat. Went into a bar and came out a little later and when he started it it popped and then nothing. The crankcase on that cylinder filled with fuel. Bent a rod.
Can you twist the "angle" of the fuel line inside the tank without disassembling the grommet? How do I dissassemble the grommet?
Had a similar problem on my 99 Vmax. I replaced the pickup line and filter. You can remove the fitting on the tank which will give access to the pickup line connection. I used a flexible grab tool to run the new line down.
