piersol
I have a 91 phazer II st long track that I brought back from the dead. Next step is to pull the rear skid and go through it.
I weigh 300 lbs when all geared up to ride. As of right now, even sitting on the sled at a dead stop I bottom out the skid. What do I need to adjust to get the most clearance / stiffest ride?
Throttle Junkie35
You could make taller front spring hooks, you could drill new holes a 1/2" back farther on the rails where the rear arm attatches. Or try new springs.
piersol
Good ideas, thanks! I'm really lost when it comes to suspension adjustment.
