Rsi three wire handwarmers need wiring diagram and input quick!
mrsadak14
Western mass
Wiring has me stumped on rsi 3 wire to the Yamaha 2 wire circuit. Rsi says to hook blue and red wire together and I assume that means to connect those 2 wires to either the Yamaha yellow or black wire. Then do I take white wire coming back off that same hand warmer and send it across to the other red and blue wire on other side hand warmer and then send that white wire back to either yamahas yellow or black wire.
You can either wire them in parallel or in a series. Parallel gets you more heat just a bit more draw on stator. The wires on the sled are nonspecific. So for parallel take the red and blue to one led from sled harness and the white to the other. Then do the same to the other grip and give a test. All red and blue to one lead and whites to the other gets ya parallel. For a series it should be red , blue to sled lead then white to red blue of other grip then white to other lead from sled and test.
