chrisgorski
Not sure why this is happening, twice in 2 years, right side piston over heated, rod bearing shot, not sure about crank bearing until I finish taking the engine out and the case apart. Cylinder was getting coolant, plug looked a little black, oil reservoir was full, no warning light on. Need to find the cause so it doesn't happen a 3rd time, my other Viper seems bullet proof but this problem one is just that. Any cause suggestions are appreciated. Thanks,...chris
Labrador-Ronin
I hate to say it, could be the coil not working right, could be either too rich or too lean, had a enticer 340T and same thing, I wanted to take it apart, dad shot it with a slug haha, I says check the carb, cause it might be lean, too lean and running hot
Sent from my D5106 using Tapatalk
drew24
Carb could need cleaned. Bad crank seal could also be a possibility.
