Hey guys was out all weekend on my srx it's running lot a top but we got a lot of snow with no base and my 136 ripsaw works well but the skis are so skinny the belly pans doing the work lol who had this problem and what's a good wide mountain ski ?? ThNx guys !!
I run powder pros by slp. I like em but they are kinda heavy.. Cheapest new option would be the camoplast (all terrain)I think. They are only available in black but super light and seem good, buddy rides with them.
Sent from my XT1080 using Tapatalk
Throttle Junkie35
Sounds like you modded to a 136" skid and track?? Try lowering the rear suspension mount, shorten up your drop brackets, or tighten up the rear limiter strap. You will be very surprised what happens when you lower the rear and take pressure off of the skis. The sled will float and climb out of the deep stuff much...much better.
A couple of bucks
Youllbe2nd
X2 on the camoplast. I put some on Polaris and was very impressed. Less than half the price of the c&a
Sent from my E6560C using Tapatalk
low slung
6 inch wide tuner skis from Yamaha Canada.....or these bad boys(be sure they fit a trailing arm sled first)http://www.totallyamaha.net/forums/...stic-skis-on-EnticerII410?p=656673#post656673
JERSEYJOE
I run APEX skis on Viper spindles
