Srx 700
holle09
Is there a way to adjust my belt on my srx? seems like it's to tight it likes to squeal when it's idling
there are 3 screws in the back of th secondary. Add or subtract washers to set the belt heighth.
What he said.
The farther in the bolt goes, the wider the sheaves are held open and the lower the belt will sit. So, remove washers to lower belt, add washers to raise belt. You want to target flush with the top of sheave to an 1/8" above.
The ends of the 3 bolts are also made to wear, so if they are too badly worn down then get new ones and start from there.
With Your sled on the stand, the track should just creep or just be on the brink of turning all by itself. If all it needs is a little help with a touch of the throttle then your good. Adjust the three screws that mod-it mentioned until you achieve this. Clean your clutch sheaves where the belt rides with scotch bright and carb cleaner. Inspect belt too.
Sent from my E6560C using Tapatalk
