Substitutions for parts that are no longer made?
norwegian
Well-known member
norway
Hi
90185-10120-00 (nut for upper center shock mount) is discontinued. What are the thread dimensions? Are they metrical, if so, what are they?
91A20-07030-00. Fuel hose in gas tank. Can I use insted of that: 8CR-24335-00-00 PIPE, SUCTION 1 and 90468-04092-00 CLIP?
Does anyone know whether this will fit?
thanks.
All threads on sled will be metric. I don't know your situation over there in Norway, but I'm guessing you might not be able to run to the corner hardware store and match up the a nut, otherwise you'd have done that already. I don't know what threads are used there, but maybe someone will chime in with that info.
As for the gas line, I'd think you may have to run your own custom made version.
If the threads are 10mm x 1,25 pitch or 10mm x 1,5 pitch, ther should not be a problem. As for a gas line, well, I ordered it anyway, we'll see.
Is it made for cold temps as well? Boats.net had the 91A20-07039-00, so now I will have that as well as the 8CR-24335-00-00
